To my dis-pleasure, my 10 yr old Lincoln Vista 3000 helmet, is choosing to randomly and unpredictably flash me. To be clear, I strike a TIG arc on carbon steel, generally my helmet darkens immediately, then 5-30 seconds into the weld it reverts back to normal.... often times, it then jumps unpredictably from darkening on, off, on, off.... etc. until I get off the pedal.
Generally it's been an ok helmet, no flashing.... until now. I suspect this unpredictable behavior is due to my attempt at TIG welding in 20F temperatures. So I'll blame the arrival of colder weather.
Looking at the specs for new helmets (low end or even the top of line Optrel, Miller, Lincoln, etc.), they do not seem to indicate their suitability for welding in colder temperatures. Optrel does indicate an operating temperature of -10C to +70C but not sure if I should have total faith in that statement alone.
My minimum criteria for a new helmet:
- great clarity
- superior fitment for:
- prescription eye glasses, and
- 3m respirator (half mask style)
- auto darkening works flawlessly in colder temperatures (down to at least 20F)
- does Miller X-mode work flawlessly in colder temperatures ?
- what manufacturer specs should I look for, to ensure any proposed helmet auto darkens in colder temperatures ? (or is this just wishful thinking on my part ?)
- any recommendations on helmets that measure up ?
