DavesTent
    Sun Feb 09, 2020 7:05 pm
    Southwestern Ontario
Beginner here, just learning TIG. Welding AC on 0.130 AL at about 120 Amps, stubby gas lens with #5 tip and 12-13 Lpm argon, 2% Lanthanated 3/32. Everlast PowerTIG 185. Running practice beads and figuring out what the machine wants to be set at. Had some decent welds then this happened? Switched to a fresh tungsten and never happened again. What causes this?
Never stop learning!
Canox MIGmatic 35
Everlast PowerPlasma 50
It's related to post-flow. Too short of a post-flow and the tip, possibly more, will get oxidized.
hey_allen
    Thu Mar 05, 2015 6:09 pm
    SW Oklahoma
I've had similar when I ended up with a leak at the torch head, and pulled air into the shield gas flow.
If bumping post-flow up a little doesn't fix it, you might start checking for leaks around the cup and back cap.
-Josh
Greasy fingered tinkerer.
It can also happen if you have the habit of quickly pulling the torch away, the action of the torch moving fast enough that the argon can't protect the tungsten
DavesTent
Thanks everyone! I'm assuming that it was probably me moving the torch away too quickly as the before and after passes did't produce the same issues. That's a good tip to check for leaks at the torch as well, I'll file that one away for next time.
Canox MIGmatic 35
