    Sat Feb 17, 2018 10:10 pm
    Carberry, Manitoba, Canada
Does anyone know what the snap down feet on this table would be called? Or where I could find them? I want to build a smaller table I can wheel around, but also be able lift it off of the wheels to keep it sturdy. And ideas or pics much appreciatedImage
BugHunter
    Sun Apr 19, 2020 12:54 pm
You're looking for a floor lock caster. Some call them a truck lock, some will call it a kick bar caster, do some Googling and you'll get the idea.
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
the other is side mount casters. you push the casters down to lift the table off its feet onto wheels. that way most of the time its sitting on normal feet and the mechanism only takes load when moving.
the one in the pic has all the weight going through the lifting mechanism which is not goof for safety, wear and tear and stability.
https://www.machineryhouse.com.au/W935
BillE.Dee
    Mon Nov 27, 2017 8:53 pm
hey Jay,,,wouldn't you rather move on the casters and sit on the legs? By looking at what 's there, you could rearrange the casters to mount on the jacks for moving and lower to the solid legs. Just a thought in case you want to dance on the table.
gramps
BillE.Dee wrote:hey Jay,,,wouldn't you rather move on the casters and sit on the legs? By looking at what 's there, you could rearrange the casters to mount on the jacks for moving and lower to the solid legs. Just a thought in case you want to dance on the table.
gramps
Absolutely. I like the ones tweake posted, ill look around see if I can't find any. 'Preciate it, Thanks!
BillE.Dee
I think I saw those on amazon, jay. I tried to look up retractable casters
Those are about the only ones i found, I don't think they're heavy duty enough for a 4x6 with a heavy top. I might just try and make my own.
av8or1
JayWal wrote:Those are about the only ones i found, I don't think they're heavy duty enough for a 4x6 with a heavy top. I might just try and make my own.
If you do that, I would request that you create a build thread for it. I would be quite interested in seeing what you come up with!
BillE.Dee
Cant ya just transfer your wheels to the jacks and make leg extensions? OR shorten the jack mounts? Don't ya know a weldor?? :?
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
We use those on big trolleys to lock them in place without having to lock all the wheels. Usually two on opp diagonals. I don't know what they are called though.
BillE.Dee
hello Jay,,,,just pickin a bit. I did find some guy who made his own retractable casters on a yt channel while looking up retractable casters. https://www.youtube.com/watch?v=c_Ksvq3OBlQ I "think" it's this one. lots of cutting and fitting.
JohnMc
    Sat Aug 12, 2017 5:42 pm
    Ontario, Canada
Toggatug
    Sat Mar 25, 2017 12:06 pm
    Ontario, Canada
Pretty sure I've seen them at princess auto if your in canada.
I also have a light duty set off of Amazon think it was only 100lb per caster though
DavidR8
    Fri Apr 17, 2020 12:50 am
    Vancouver, Canada
@JayWal I personally know the owner of the red table. I can ask where he got the casters.
David
Millermatic 130
Primeweld 225
DavidR8
    Vancouver, Canada
@JayWal those casters came from Princess Auto though they may be discontinued now.
David
Millermatic 130
Primeweld 225
Toggatug
    Ontario, Canada
Well that makes sense why I can't find them on their site now. Definitely have seen them in the store before.
Toggatug wrote:Well that makes sense why I can't find them on their site now. Definitely have seen them in the store before.
I'll have to go and see what they have, I couldn't find em on their site either
    Sun Oct 10, 2021 3:52 pm
These are the standard table legs
metalmagpie
    Mon Jul 15, 2024 12:58 pm
Bassick is the industry leader in floor locks. They are generally sized by the caster wheel size. If you have 4" wheels buy a 4" floor lock.
But floor locks do not lift the table off the floor. If you need feet that lift the table off the floor then you need a different design than floor locks.
Timmy_Tiggs
    Thu Sep 19, 2024 8:13 am
There is an alternative method.
