Bill52
    Thu Jan 28, 2021 3:44 am
First TIG 'welding'.
Setup:
- material: 4 mm mild steel
- type: DC
- current: 100 A
- electrode: 2.5mm 2% Ceriated
- polarity: positive handle
- cup: #5
- gas: pure argon
- flow: 7.5 l/min
- pre-flow: 1sec
- no filler
Result:
Well, can't call it a weld but the two pieces of material did melt together.
Also melt the tungsten and the bottom of the cup together into a ball.
Tried searching for 'tig cup melted' on google but nothing came up so far.
What am I doing wrong?
Thanks in advance.
    Wed Jan 22, 2014 12:00 am
    Connecticut
Your polarity is backwards. The tungsten should be electrode negative.
Multimatic 255
    Sun Oct 27, 2013 10:57 pm
Yep, what Louie said :)
walz10
    Sat Jan 16, 2021 10:55 pm
What the posts above said or possibly extreme porosity
walz10
walz10 wrote:What the posts above said or possibly extreme porosity
Pictures really help
    Sat Feb 17, 2018 10:10 pm
    Carberry, Manitoba, Canada
Bill52 wrote:First TIG 'welding'.
Setup:
- type: DC
- current: 100 A
- lens: #6
- gas: pure argon
- flow: 7.5 l/min
- pre-flow: 1sec
- no filler
Result:
Also melt the tungsten and the bottom of the lens together into a ball.
Tried searching for 'tig lens melted' on google but nothing came up so far.
Thanks in advance.
Had the same issue when I struck my first arc. After an hour Googling how to strike an arc I found out Tig torch should be negative. Works a lot better! [emoji846]
William Payne
    Sun Jan 17, 2021 6:15 am
    New Zealand
Yip TIG is EN electrode negative.
However post some pics I’d love to see this.
Miller Syncrowave 350LX
Esab Power Compact 205
BOC 185DC Tig
Spartan
    Fri Mar 06, 2020 8:59 pm
Also consider upping your amps once you get the polarity sorted. 100A is quite low for 4mm thick steel.
Bill52
JayWal wrote:However post some pics I’d love to see this.
As you asked for it ... my latest art work.
For those who didn't know, this is how to TIG weld gas-lenses.
I'm taking orders. Send me your perfect lens and receive something like this. :)
Haven't tried the reverse polarity yet. I'm sure it'll work. Better tan this one ...
tweake
    Mon Dec 18, 2017 4:53 am
    New Zealand
its not actually a lens.
thats the cup and tungsten melted together.
i would go up a cup size or two.
eelman308
    Tue Dec 29, 2020 10:34 pm
    Illinois....for now
:o
Bill52
Well, the electrode-negative and the larger cup - #6 - worked.
Wouldn't call it a weld but the two pieces are not falling apart - it's a start.
Many thanks for all of you!
