linkline
    Sun Mar 21, 2021 11:22 pm
So I attached picture of what i was told is a cast aluminum, but I dont know the type. What materials, what's the best way to prep these for weld fix? What do I use to clean this, restore it as new, any advices..?
Would it be wire brushes, drill, acetone, etc? Just trying to prep it for a friend, those 6 brackets were from the truck side steps, nd there are some layers peeling off which I'm clueless what it is, much is appreciated for advices!
Couple broken pieces
Clean them to bright shiny aluminum. Then preheat them to above 350*. Then chemically clean them with acetone. If the breaks fit back together cleanly, V grind both sides to bevel both pieces. Then weld it up. Expect a lot of crap to pour out during the first pass. Clean that, then do again.
Good luck. Crappy job, but it can be strong again if you are willing to endure the hassle.
linkline
cj737 wrote:Clean them to bright shiny aluminum. Then preheat them to above 350*. Then chemically clean them with acetone. If the breaks fit back together cleanly, V grind both sides to bevel both pieces. Then weld it up. Expect a lot of crap to pour out during the first pass. Clean that, then do again.
Thank you! I know this is such a noob question but what's the best way to clean em, would it be a steel wire brush or sanding paper or etc? To be honest it would be my first time deep cleaning it and prepping it, just wanted to start somewhere.
I totally understand all your other direction except preheating to 350, not sure if it's weld related or something to do with weakening cast stuff on it to make it easier?
If so, does preheating in oven work fine lol? Or blowtorch?
Again thanks a bunch, I'll definitely send in pictures of my process and final finish!
Hard to advise about cleaning without knowing exactly what the “coating” is. Downside to wire wheel is you embed more junk in the cast ally that you need to clean later. A citrus-based stripper might work well?
Preheat is to help purge the impurities out prior to welding. Cast is very porous so decades of road grime and dirty boots will have contaminated those steps something awful. Getting as much out before welding will be a Godsend. Oven works fine. 350* for 30-45 minutes. Don’t let the old lady find out!
Clean it. Heat it. Clean it. Clean it some more. Weld a bit. Clean it again! Then weld it up good.
linkline
cj737 wrote:Hard to advise about cleaning without knowing exactly what the “coating” is. Downside to wire wheel is you embed more junk in the cast ally that you need to clean later. A citrus-based stripper might work well?
I added more picture if it helps, just to make sure I'm not gonna break my hands cleaning the wrong way lol, and thank you! Much appreciated for help getting started !
Those pictures and the idea of having to weld repair them made me throw up in my mouth.
Closing thought: glad it's you and not me. ;)
BugHunter
    Sun Apr 19, 2020 12:54 pm
I would start with some truck wash. You can probably get it at your local truck stop but it might be a Walmart or Amazon deal too. Just do a search for truck wash aluminum cleaner and all sorts of stuff will come up. The stuff is amazing but it's got quite a laundry list of warnings on the label. Take heed of those.
Once you have the basic dirt cleaned up, then I would go on to something like dynaflux aluminum cleaner or any of the other things recommended here.
f_ZP5YLpkdU
linkline
cj737 wrote:Those pictures and the idea of having to weld repair them made me throw up in my mouth.
I can't believe I got the worst project as a beginner.. :"( started realizing after just cleaning em lol. But it's defiently not going to be me welding it, gonna obviously need to have experienced welder friend to do it but since you mentioned that, God I hope he's not going to be frustrated lol.
Just trying to clean and prep as much as I can :roll:
linkline
BugHunter wrote:I would start with some truck wash. You can probably get it at your local truck stop but it might be a Walmart or Amazon deal too. Just do a search for truck wash aluminum cleaner and all sorts of stuff will come up. The stuff is amazing but it's got quite a laundry list of warnings on the label. Take heed of those.
f_ZP5YLpkdU
Hmm, well the pictures I just added in, took me a few hours... I had to use flathead screwdriver to scrap off those layers that was coming off, wire brush wasn't getting em but I wire brushed em after. , quickly brushed off any crap off with plastic brush, quickly dried em down wiping off rest.
Those are the results, my next step was gonna preheat em on oven but owner's concerned about fumes which I dont blame him lol so preheating out of question.. my friend did suggest to use "aircraft removal" supposedly itll help eat em off, is this the way to go..? He said the acetone wouldn't do much..
Aircraft Stripper works well, BUT, you need to be extraordinarily careful when welding on that material afterwards. Follow the stripper with a thorough soap and water wash, then Acetone before welding.
Some chemicals, cleansers, etc when you hit them with a welding arc cause lethal off-gassing. I don't know whether Aircraft Stripper will, but be really careful anyways. You don't want to kill someone inadvertently because you didn't know and didn't tell them.
(Your last pictures linked didn't show up?)
    Wed Jan 22, 2014 12:00 am
    Connecticut
How much weight do those brackets have to hold? If it is anything significant I probably wouldn't weld those. The weld material is never as strong as the base metal you are welding unless you do some kind of post weld heat treat or hardening process. I think for the amount of time you will put into them it may actually be cheaper to replace them if possible, unless they are irreplaceable for some reason.
Multimatic 255
eelman308
    Tue Dec 29, 2020 10:34 pm
    Illinois....for now
"How much weight do those brackets have to hold? If it is anything significant I probably wouldn't weld those. "
I would agree 1000%. That's got bad written all over it.
My not at all professional opinion.
eelman308 wrote:"How much weight do those brackets have to hold? If it is anything significant I probably wouldn't weld those. "
They're for steps. He stated so in the original post. The "weight" they will hold is a human being stepping into or onto a truck. Hardly catastrophic stress. Purely safe to weld if weld by someone competent (as he says is the case).
    Connecticut
linkline, how is it those were broken? What happened?
Multimatic 255
BillE.Dee
    Mon Nov 27, 2017 8:53 pm
looks to me that those steps found an accident that found a place to happen. I did a repair on steps that "caught" a large rock and tore them all to hell. Some of the base material was missing and I did a repair as well as I could.
    Connecticut
Maybe the pics are bad or maybe my old eyes are bad. But I don't see a lot of tearing or missing chunks. It just looks to me like either a stress crack or the the step was overloaded. It would be interesting to know the back story.
Multimatic 255
Heavy duty coil cleaner like newbrite from an hvac supplier is an option. Aggressive enough to actually strip off the surface of the aluminum but water soluble for clean up.
