I would like to build a table to do oxy-fuel cutting on in my home hobby shop. My question is if I can build it with a chute to a catch pan like a downdraft table. Would I need to use a heavy gauge material for the chute or am I going to be burning it up to often to be worth building? I am trying to avoid destroying the driveway/yard.
Also I want to put in a lot of practice but don’t want to only cut large pieces of scrap into a pile of small pieces of scrap. I was thinking of cutting triangles and bolt tabs so the cuts might be useful(someday). Is there any other ideas that would make good practice cuts?https://omegle.onl/ vshare
- SlowTrafcKpRht
Hi,
Are you looking for a plasma cutting table used for Oxy/Act cutting? You know the table's slats are sacrificial.
I bought the Jegs table (see the link below) and modified it adding the catch trash can and welded wheels on it. The picture is not mine, but you get the idea.
I don't have the downdraft feature you want. I think that would be easy to plumb into the catch pan thing.
https://www.jegs.com/i/JEGS/555/81573/1 ... a9aaa8.jpg[/IMG]
