I have a small project coming up and not sure whether to mig it or tig it. Material is 42”x 24”x 0.16 6061 aluminum sheet with 1”x1”x .250 6061 aluminum angle. Welding the angle to the sheet. Only have two to build so not much production. Obviously trying to keep distortion to a minimum. Thoughts?
drizzit1aa
- drizzit1aa
Personally, I would TIG it. Course for me TIG would be faster since I am setup for TIG, an aluminum TIG weld will last longer, poetically look better and less heat input if welded right. I pretty much only use MIG if I am repairing an item.
This is MIG
Course I MIGed this also
This is MIG
- Aluminum MIG core repair.JPG (2.45 MiB) Viewed 1778 times
- 30629_118440781517655_568191_n.jpg (90.25 KiB) Viewed 1778 times
- 30629_118440784850988_1920114_n.jpg (104.91 KiB) Viewed 1778 times
- 30629_118440861517647_479562_n.jpg (83.77 KiB) Viewed 1778 times
- 30629_118440851517648_2830464_n.jpg (74.82 KiB) Viewed 1778 times
I differ from drizzle. I’d MIG it. Joining 0.063 to 0.25 aluminum is tricky to say the least. With a bit of preheat on the 0.25, and correct settings on the MIG, I think you end up with less distortion than with TIG. I’ve done 3 fuel tanks recently (2 were 3/16” TIG, the other was 1/4” MIG) and the MIG’ed tank had no distortion at all.
And I’m in the midst of building two 24x72x3/16 tables welded to 1/8 angle and TIG was a bit of a nightmare to get the sheet welded to the angle without blistering the angle. Should have MIG’ed it but my Spoolgun had SilBr in it and I was lazy.
drizzit1aa
- drizzit1aa
