I have two argon cylinders, an 80 and a 20. I exchange them for refills every so often. The smaller is my back up but when I switch them over, the setup malfunctions and it leaks.
Question: would you trade these two cylinders for the next larger size, a #4 (125) if they are willing?
vdotmatrix
- vdotmatrix
vdotmatrix
- vdotmatrix
If your shop space is so small that the extra cylinder is a problem, then trade up to a 300. But if you ever run out/low and can't get more, youre stuck. With a spare cylinder, you'll likely always have enough to get through a weekend/holiday with gas when its needed.
To each their own-
But that still doesnt explain why your setup fails after a bottle switch???
To each their own-
My thoughts, too. I have 2 medium cylinders. It's worth paying the rent on them annually, as I got stuck without gas on two separate weekends and couldn't do much of anything. I vowed not to let that happen again.
It's the loss of gas that's an issue - you've got a bad connection if you're leaking. Are you thinking there's something wrong with the bottle itself? I've found it's usually my technique putting things together that lets gas leak.
metalmagpie
- metalmagpie
Don't trade them for a 125. Lots of those are leased or rentals. Trade for a 150, because those are all customer-owned so you know you're safe. Plus, a 150 is almost exactly the same cost to fill as a 125 and you get 20% more gas.
