77cruiser
    Tue Jan 31, 2017 10:27 am
    Frostbite Falls, MN
Picked up some Excalibur & the slag seems real hard to remove, a lot harder that the Hobart 7018 that I was using.
Is that the way it is?
It’s been my experience that amps help when the slag is tough to remove. Got any pictures you can post?
77cruiser
    Frostbite Falls, MN
cj737 wrote: ↑Sun Jun 08, 2025 10:48 am It’s been my experience that amps help when the slag is tough to remove. Got any pictures you can post?
It's done & painted. Can't remember how to figure the amperage, 60% of the 40-190 range. So I think it should be around 130A kind of high for 3/32 7018 maybe.
I run 90ish amps for 3/32. I’m right about 122 for 1/8.
At 130amps I’d be on 1/8, and running long extension leads allowing for the drop and I’d be holding a cherry bomb for an electrode!
77cruiser
    Frostbite Falls, MN
The leads aren't too long 25' ground & maybe 35' for electrode, I've always thought the amperage was low on this welder. Suppose I could try my Thunder bolt & give it a try, I don't think I've ever ran it over 110-115 on 3/32.
