Used an old hand-sledge we found out shooting. Came out okay.
- DSCN4595.JPG (123.13 KiB) Viewed 42905 times
Everlast PowerTig 250EX, PowerTig 185 Micro, PowerArc 160STH, Miller Trailblazer 301G, Millermatic 140 Auto-Set
ArcherAndy
- ArcherAndy
I really like that idea! I have been wanting to try and build a 3rd hand. Very resourceful use of materials.
Miller Syncrowave 250 water cooled TIG
Ok - slightly different outlook on the 3rd hand thingy ! I'd never worried too much about it , but recently when altering a mirror finished stainless steel part it arced badly on the bench & made me say " DARN " ! so the hammer head was laying under the bench as was the 1/2" & 3/4" square - I figured making it touch at 3 points would be naturally more stable & the hammer head can be slid up & down to excert more weight if needed - the feet are rounded in 1 direction but flat across giving more choice - their clad in copper sheet to improve conductivity - I also bolted a bit of 1/4" flat copper on to "light up on" after grinding the tungsten as I manage to sweep them off the bench otherwise.
- IMG_1114.JPG (92.73 KiB) Viewed 42706 times
- IMG_1115.JPG (93.26 KiB) Viewed 42706 times
That's sweet! I like the sliding weight.
Do you have the copper bonded to the steel in any way? Solder, or something?
Yes- the copper is soft soldered to the legs for conductivity - but could be changed if necessary.
Weber Sarge
- Weber Sarge
Here is one I made last winter with a sliding weight -
The tip and ground faces on the round tubing are copper building wire that were tig welded directly to the steel , then turned down in the lathe . No more arc marks on work , big help for sure .
Sarge
Sarge
Nice job - I like the sliding weight - looks good.
Wish I'd had more copper around when I made mine but it's not a material I really work with - had just a few offcuts of sheet under the metal shear so that had to do.
Glad to see someone else with a lathe - began to think I was the only member with one ( actually it's several plus Milling machines etc - someone recently called me a "low buck Keith Fenner" !! not sure how to take that & I don't have the weird beard thing going on ! )
Very impressed with the sledge hammer third hand, but I can't resist commenting that the steel in a sledge hammer is (usually) high carbon content, and is very, very useful. I have even seen one used as an anvil for knife making. Ah well, you know where it is if you need the steel for something else. Well done.
No issues, and so far for the work I do, my adjustable Set-Tru (0.0002" TIR), 6.25" Bison 6-jaw is THE best upgrade (the DRO being the second) I have done to my lathe.blaz wrote:I see a 6 jaw chuck there. That will be my next chuck I think. Any issues?
LOL wish I had the room or even the money but when I can afford it I want my own machine shop and complete welding setup with plasma cutters and a 4'x8' CNC plasma table toonoddybrian wrote: Glad to see someone else with a lathe - began to think I was the only member with one
I come from the "other side". I am already a machinist, with a small machine shop (lathe, mill, accessories, etc.) and I am now starting on the welding, but it will take a long time and a LOT of saved money before I can have a "welding shop"Ranger wrote:LOL wish I had the room or even the money but when I can afford it I want my own machine shop and complete welding setup with plasma cutters and a 4'x8' CNC plasma table toonoddybrian wrote: Glad to see someone else with a lathe - began to think I was the only member with one
Will
- Responsible
I built this one when I was practicing 'T' joints. Made setting up easy.
- Third Hand 2.JPG (238.95 KiB) Viewed 24212 times
- ThirdHand.JPG (175.97 KiB) Viewed 24212 times
Weber Sarge
- Weber Sarge
Don't sweat the copper issue - it's just building wire stripped and sanded clean , it was "good enough" for a third hand project . I've got a nice old Enco 12x36 , a bit sloppy but for most of what I need it works great .noddybrian wrote:Nice job - I like the sliding weight - looks good.
Sarge
Hey,
I finally got around to making some 3rd hand tools. 1 monster, 1 smaller and 2 matching (sort of) ones,
- 2013-10-31_15-05-04_554.jpg (544.4 KiB) Viewed 26077 times
- 2013-10-31_15-04-16_767.jpg (562.01 KiB) Viewed 26077 times
I like them
When I did mine, I noticed they would still make small black arc strikes on my aluminum. Jody showed the same and used silicon bronze for the ends I believe.
I did not have any so I used house electrical wire and tigged some copper on mine
