- GreinTime
Some 2x.250 wall Mild steel control arms I'm welding for a buddy of mine. You boys that weld pipe have my respect, that thick stuff is no joke!
- 5th Street Fab
Some stuff from the last 2 weeks.
Last edited by 5th Street Fab on Sat Mar 25, 2017 12:17 am, edited 1 time in total.
- 5th Street Fab
Thanks zank. Love your stuff!zank wrote:Beautiful stuff!
5th Street Fab wrote:Some stuff from the last 2 weeks.
Gotta get a napkin after this one... Hot damn.
How the F do you get consistency like that? Looks like a (curse word) robot welded that stuff.
What's your settings? I want to be like you when I grow up.
I couldn't weld like that in my dreams! Damn! Beautiful work 5th Street
Pete
- Farmwelding
As if you weren't going to practice more. No welder on here doesn't need more practice nor do they not practice.electrode wrote:I better go practice some more...
- 5th Street Fab
Thanks guys. I don't have any settings really it's just a transformer syncrowave 250. Just 7-10 on the balance. I hate having a long stick out on aluminum, don't know why. It just takes hood time and learning to read the puddle. Anyways thanks for looking!
Jakedaawg
- Jakedaawg
@5th Street Fab
I noticed in one of your pics an aluminum flange for an NPT plug. Is there a brand of flange or bung that you prefer? I am looking to source some to have in stock for adding drains to pontoons.
- 5th Street Fab
I'm not sure it's whatever my work has on hand.Jakedaawg wrote:@5th Street Fab
I haven't posted a weld in a while, and this topic is getting buried, so here goes.
It's a socket weld (rare for me these days) done in the position you see it with all the crap in the way. 309 rod, as it's 3/4" stainless pipe to a mild steel valve.
- socket weld.jpg (25.82 KiB) Viewed 2093 times
Nice socket weld! You used the gap-o-let right? That weldment doesn't look like it needs any mistakes. I wish I could do your job I had to weld a goddamned sink in a bar today...I hated itOtto Nobedder wrote:I haven't posted a weld in a while, and this topic is getting buried, so here goes.
socket weld.jpgSteve S
- Farmwelding
Did you get some good payment or sneak a little while you were there though. If so then probably worth it in the end. I mean you could be 20 ft down in the mud and 3 feet of water figuring out where the hell that tape measure went.exnailpounder wrote:Nice socket weld! You used the gap-o-let right? That weldment doesn't look like it needs any mistakes. I wish I could do your job I had to weld a goddamned sink in a bar today...I hated itOtto Nobedder wrote:I haven't posted a weld in a while, and this topic is getting buried, so here goes.
Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
TLAR....I'm gonna steal that from youOtto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
Be my guest! I also estimate time on task by the WAG method, which is "Wild-Ass Guess". I always look like a hero, because I use Thomas Edison's rule... However long I think it will take, I double it, then add ten percent, and that's what I tell them.exnailpounder wrote:TLAR....I'm gonna steal that from youOtto Nobedder wrote:Gap-o-let? I just cut the threads off the pipe section you see (Originally a threaded nipple. I was expecting Rego valves, with FNPT both ends). I then loosely fit these ITT valves (this has a mate exactly opposite) for the standard 1/16" minimum pull-back for a socket weld, used my electrician's level to set the valves at 30*, and a quick tack on top. Squared them up with my TLAR (That Looks About Right), and welded them out.
Under-promise and over-deliver, and they'll beat down your door.
- RocketSurgeon
It's been a while since I posted anything substantial.
First time on 304 SS 1 1/2", 1" and 1/2" sch 40. Two passes. Argon purge at 10cfh. 3/32 2%Thoriated with #7 cup (wishing it was an 8).
- 20170414_123353.jpg (27.59 KiB) Viewed 2207 times
- 20170414_123345.jpg (30.78 KiB) Viewed 2207 times
- 20170414_123334.jpg (41.7 KiB) Viewed 2207 times
- 20170414_084546.jpg (37.97 KiB) Viewed 2207 times
- 20170414_084535.jpg (38.37 KiB) Viewed 2207 times
- 20170414_084517.jpg (28.34 KiB) Viewed 2207 times
Chris
AWS D1.1, D17.1
AWS D1.1, D17.1
- GreinTime
Getting the hang of these exhaust flex sections! 3" 304, backpurge at 7cfh, welded at 90a w/ 1/16"308L. Pictures arranged chronologically from out of the bag to welded, for those of you who have never had the unfortunate pleasure of welding one!
