Very nice!
Don't you hate hiding the good stuff?
Moz
- MosquitoMoto
- 5th Street Fab
Ya it was a bummer after I installed it haha oh well!MosquitoMoto wrote:Very nice!
Moz
the welding process is smaw (stick) we use 7018 for the vessel. This weld is a code or stamped weld it will be QCed under 31.12 boiler code ( no under cut or any indication while they pt it) and stamped with ASME stamp .after that we will hydro the tank to 300 psi twice the stamped pressure. This vessel is apart of a water treatment plant for a power house. Definitely not glamorous but I love what I do and being challenged every day and pushed to weld at a very high standard has put me and a very fortunate situation!Coldman wrote:Maybe not glamorous to you but involves serious skill and experience. Good job!
Now you have to elaborate on process and procedure used please.
Had to repair some dirty old stainless can't always be weldporn with new material at a bench. There is something satisfying about welding all curled up like a pretzel.
I couldn't get to the backside of this weld really good to clean a couple spots gave me issues.
- All ground out
- IMG_20170703_103237349.jpg (25.23 KiB) Viewed 3282 times
- IMG_20170703_112641899.jpg (24.54 KiB) Viewed 3282 times
- IMG_20170703_133703977.jpg (21.93 KiB) Viewed 3282 times
We all know that's true, good work as always RickRick_H wrote:Had to repair some dirty old stainless can't always be weldporn with new material at a bench. There is something satisfying about welding all curled up like a pretzel.
Bingo wrote:Well on this Friday we get back in our tig rigs 4" sch 40 70s6 ( not my favorite wire for carbon) welding under code 31.3
Nice work, I prefer 70s2 if allowed personally.
Making a new turbo back system for my MK4 TDI, 3" dp, 3" straight system....and I know you guys are shocked it's stainless and sanitary welded.
- IMG_20170707_112251881.jpg (43.72 KiB) Viewed 3804 times
- IMG_20170707_112225483.jpg (40.09 KiB) Viewed 3804 times
Only until he fires it up...Bingo wrote:Clean!
I'm going to have to work on my pipe welding, I want one for my TDI, but can't stand the thought of paying what the commercial offerings are asking!
-Josh
Greasy fingered tinkerer.
Yeah there was no way I was going to pay near $300 for a DP, I actually don't have a ton of money in everything front to back. I bought some fittings from Andron Stainless, if I knew how to pie cut or.could easily cut those at home I would have saved even more. It's been fun...have to mock it up today to get the angle of the DP right and make the middle section....then just weld it and add hangers. I used a 2"-3" reducer at the flange so I'd have bolt clearance, and a Vibrant Flex joint.hey_allen wrote:Only until he fires it up...Bingo wrote:Clean!
- GreinTime
Prototype done for the 10th Gen Civic Intercooler and Charge Pipe setup.
First time welding cast with 5356, can't say I'm really a fan. I don't know if I'll get to weld anymore of these, but we'll see if I can weld one with 5356, 4043, and 4943 back to back to back (batch work is nice for testing some times) with identical settings and see who can tell what!
Awesome work Sam...
Pete
- 5th Street Fab
Welded this today.
This will have a big tower mounted on top like the last one I built. They wanted it to hinge on 2 small brackets, but there's no way it old hold plus the brackets were way off so I built a doubler and gussets.
This will be really cool when it's done I'll show you guys later hopefully.
Keep forgetting to post my experiences with SolarFlux. This stuff is gold if backpurging stainless isn't reasonable or practical. I use it with ISO alcohol, works GREAT!!!
- IMG_6212.JPG (89.88 KiB) Viewed 3033 times
After, I tried to keep the tacks shallow. I didn't clean it all up since it's just an exhaust pipe but I wiped off an area with acetone and it's nice and shiny metal underneath.Poland308 wrote:Did you butter up the two halves before or after you tacked them up?
Cool! I was wondering if it would interfere with the weld process if it was worked down into a crack. I'm envisioning that you might be able to coat the two sides before you tack up. If there was no way to get at the joint after fit up.
