I came across this article about the strength and durability of weld joints in 6061-T6:
http://www.intrepidequipment.com/handcy ... rials.html
In summary, a quote:
"The most important thing when considering aluminum is the ease with which they can be welded, and the strength of the weld.
When aluminum is welded, the weld zone becomes annealed. The key difference between the alloys is that 7005 recovers some of its strength after welding in a process known as age hardening (or low temperature precipitation hardening), while 6061 requires an expensive high temperature heat treating process to regain strength and temper.
• 7005 has approximately 60% of its original strength after welding and age hardening.
• 6061 has approximately 30% of its original strength after welding."
Two questions:
1) Is the writer correct about the post weld condition of 6061 and does it require as much treatment as described?
2) Would using a slightly more flexible filler rod such as 4043 reduce such a problem or not?
Thanks,
Scott
