Jeff, do you back purge those kegs when welding the fittings?
I do. I bought an argon bottle just for that purpose. I have made various purge boxes for sparge tanks and HLTs ( kegs with the top cut out) and have a nice setup for intact kegs. Been working out great. Welding thick to thin can be tricky...need to move fast but stainless welds so nice is has gotten easy. I love welding stainless. Your work looks nice.AndersK wrote:Jeff, do you back purge those kegs when welding the fittings?
Had an idea for a work light I had to get out of my head.
Made it from aluminum and steel. It has a 5,5W LED light in it and is fully adjustable in all directions
Some welding content
The steel parts are 0,9 mm thick, thinner at the rear dome after all hammering.
Welded with minimum of filler and then planished.
- IMG_20160127_51490.jpg (51.5 KiB) Viewed 3976 times
- IMG_20160127_27168.jpg (28.24 KiB) Viewed 3976 times
- IMG_20160130_1258.jpg (33.35 KiB) Viewed 3976 times
- IMG_20160130_13116.jpg (34.18 KiB) Viewed 3976 times
Another Metalshaping project.
- IMG_20170927_10826.jpg (68.12 KiB) Viewed 3805 times
- IMG_20170927_1162.jpg (61.89 KiB) Viewed 3805 times
- IMG_20170927_42741.jpg (36.99 KiB) Viewed 3805 times
- IMG_20170927_3675.jpg (34.77 KiB) Viewed 3805 times
- IMG_20170927_47992.jpg (30.26 KiB) Viewed 3805 times
- IMG_20170927_4602.jpg (24.51 KiB) Viewed 3805 times
- IMG_20170927_40805.jpg (29.55 KiB) Viewed 3805 times
- IMG_20170927_7266.jpg (37.93 KiB) Viewed 3805 times
- IMG_20170927_52102.jpg (35.64 KiB) Viewed 3805 times
- Wood Welder
This box is awesome. I tried metal spinning on my lathe to make an 18" Venturi and it was a disaster.AndersK wrote:Not any welding here, just wanted to show a box I made for my gas torches.
Made in 1,5mm aluminum with stainless handle and hatch.
Once again, I could by a cheap box but what do one learn from that?
I could have welded the lids so the rivets is just for the cool factor.DSC_0333.jpgDSC_0331.jpgDSC_0332.jpgDSC_0336.jpg
Can you guide me to a video of the process to form metal like these boxes? The details are incredible.
Lincoln 100 amp transformer MIG w/flux core wire
HF TIG w/no pedal for steel & stainless, Stick w/3/32 6011,7018
Formerly: Victor O/A and Lincoln 225 AC buzz box
Looking to upgrade
Bikes-XR250, CRF230
Looking to upgrade
Bikes-XR250, CRF230
The technique I use is called hammer-forming, used on both the box and the Porsche clock.
Good resources are Ron Covell, Peter Tommasini and David Gardiner among others.
Ron has a movie dedicated to hammer forming:
http://covell.biz/hammerforming-techniques/
The details on the lid are made differently though.
1. Make a die of the shape you want. Can be of metal, wood, plastic you name it.
2 Make a "sandwich" bottom-up : The Die, the sheet to form, a urethane pad or hard rubber, a thick steel plate
3 Place that sandwich in a press and squeeze.
Below is an example I made with a steel die in 0,5 mm stainless
- zoom1.jpg (52.75 KiB) Viewed 3451 times
- zoom2.jpg (55.94 KiB) Viewed 3451 times
- zoom3.jpg (235.77 KiB) Viewed 3451 times
Bench shear, jig saw and files. All hand crafted
Yes, they are spot welded. If you zoom in you can see the darker spots.
Laser cutting would had been a lot easier but this was just a fun weekend project at a Metalmeet in Norway.
Looks brilliant mate, like a heavy duty flight case!AndersK wrote:Not any welding here, just wanted to show a box I made for my gas torches.
Thx mate.
It's been in my mind making one for sure
Another box made, at least it has one weld in it....
- IMG_20171228_1091.jpg (27.87 KiB) Viewed 3126 times
- IMG_20171228_21459.jpg (30.54 KiB) Viewed 3126 times
- IMG_20171228_46102.jpg (28.47 KiB) Viewed 3126 times
Thx guys
Top and bottom is 1050A 1,5mm
Shroud is 5052
Shroud is 5052
- 5th Street Fab
Ya I saw this on Instagram! Nice job I like it a lot!AndersK wrote:Another box made, at least it has one weld in it....IMG_20171228_1091.jpgIMG_20171228_21459.jpgIMG_20171228_46102.jpg
Sent from my XT1635-01 using Tapatalk
