Yes. XS750 with a XS850 engine rebuilt with higher compression xs1100 pistons, undercut trans, new rods, polished crank, eventually a ported head. Busa front forks and triple. Fun project going on one year.
I don't know what to do with the rear. The braced frames I've seen don't seem to address it. I'm wondering if it matters less because it doesn't effect geometry as much as long as the swinarm pivots to the steering head maintain the correct geometry.
Believe it or not, those tubes went on for about 6 more inches then terminated. a rear cowl with grab-bar and fender bolted to the rear. I was thinking maybe some simple gussets as long and it clears the rear tire.
What do you think?
