batilden69
- batilden69
Im knew to this so please bear with me. I work as a welding suppervisor in a shop where we build alot of prototypes and one offs of rail and mining equipment. My experiance is almost exclusively MIG, almost 0 TIG altho i do have one here(dont know how to set it tho). My dilema is that we have a knew customers and with it brings a whole lot of High Pressure Hydraulic Lines. I have done alot of air line and some hydraulic tanks, lines ect. but nothing like the 7-10,000 PSI that these require. Can someone help me with right process. I dont want these things blowing out and costing my bosses lots of money or worse, hurting somebody.Any help i can get would be greatly appreciated!
Adam's Got Skills
- Adam's Got Skills
What size are the lines? What kind of SS? What kind of pipe/tubing...(thickness, Outside Diameter, inside diameter)? I would definitely recommend TIG welding that kind of thing. It's the easiest way to get the best weld on hydraulic lines. I imagine your doing socket welds. You could also use Swagelock (sounds like "swedge-lock") compression fittings but they are $100+ a piece. I've done quite a bit of this so gimme some details and I'll give ya any knowledge I got
Welcome, batilden69,batilden69 wrote:Im knew to this so please bear with me. I work as a welding suppervisor in a shop where we build alot of prototypes and one offs of rail and mining equipment. My experiance is almost exclusively MIG, almost 0 TIG altho i do have one here(dont know how to set it tho). My dilema is that we have a knew customers and with it brings a whole lot of High Pressure Hydraulic Lines. I have done alot of air line and some hydraulic tanks, lines ect. but nothing like the 7-10,000 PSI that these require. Can someone help me with right process. I dont want these things blowing out and costing my bosses lots of money or worse, hurting somebody.Any help i can get would be greatly appreciated!
I've done quite a few code welds that I had to test to 9680 PSI (this was 1.25 X MAWP of 8800PSI). The service was liquid hydrogen, not hydraulic fluid, but the piping was all 3/4" 304 SS, schedule 160, and because of the pressures it had to meet ASME IX B31.9. It was TIG all the way, and the customer required 10% of my welds to be x-rayed. For convenience, the x-ray averaged 25%, but regardless, at those pressures, boiler code will most likely apply (as the best system to have esablished WPS's and standards for those pressures.
I'm with Steve, that application should have a WPS or have one established/created. Tig all the way and I'd expect an xray and bend test minimum.
Any one that considers welding a high pressure line should be aware what effect even the smallest pinhole or crack could have if a hand gets into the leak path. Fluid under high pressure that leaks thru a crack or pinhole can cut thru a hand that at first look looks like nothing to worry about that later leads to a long and painful treatment.
http://www.safequarry.com/toolbox/Highp ... juries.pdf
Good reminder - one of our local farmers got "injected" with hydraulic oil in his leg.AndersK wrote:Any one that considers welding a high pressure line should be aware what effect even the smallest pinhole or crack could have if a hand gets into the leak path. Fluid under high pressure that leaks thru a crack or pinhole can cut thru a hand that at first look looks like nothing to worry about that later leads to a long and painful treatment.
