beerrun wrote:Friend of mind crashed his 2014 Jeep, bent both tubes out of hoghead. He thinks i can fix it... anyone had any experience at welding cold roll to cast?
It might stick, but will crack under the lightest load.
Using Ni-Rod would be my choice. I've used 309 in a pinch as well
some times cast/forged steel parts are confused with cast iron due to appearance
if it is suspension parts, replace
safety first
safety first
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
safety first
safety first
Everlast 250EX
Sprockmonster
- Sprockmonster
Are you sure its not plastic?!?[SMILING FACE WITH OPEN MOUTH][SMILING FACE WITH OPEN MOUTH]... Nowadays all these companies are trying to cut the weight... [SMILING FACE WITH OPEN MOUTH][SMILING FACE WITH OPEN MOUTH AND SMILING EYES]
jwright650
- jwright650
Are those axle tubes plug welded into the cast housing from the factory like the older stuff was? My 70 Camaro had a half inch of grease around those joints where the tubes were pressed in and plug welded at the factory. I cleaned off the grease to find the source was those factory plug welds that had burned all the way through and were leaking through the factory plug welds. Took me a few tries to get the area clean enough to repair those welds(already had the axle out and apart putting in a posi-carrier), so it wasn't too bad of a job.beerrun wrote:Friend of mind crashed his 2014 Jeep, bent both tubes out of hoghead. He thinks i can fix it... anyone had any experience at welding cold roll to cast?
I'm leaning towards what these other guys are suggesting about leaving it alone due to liability issues...it's a sue happy world we live in today.
John Wright
