It would be very interesting to see a theory of operation for Bobcat and Trailblazer. If the old Lincoln pipeliner machines were so very sweet, what set them apart from newer machines. I do know a Bobcat does not weld as nice as a Trailblazer, but an expert can still do OK. Is the Bobcat missing something essential? or the old Lincolns overrated?WerkSpace wrote:What model of stick welder are you refering to?
http://www.lincolnelectric.com/Assets/U ... VM224A.pdf
http://jacobs-online.biz/understanding_transformers.htm
Bill Beauregard
- Bill Beauregard
I bought an old Lincoln SA-200 on my way home today. This welder has been converted for propane.
I tried it out and liked it, so as with everything else, it followed me home. Life is fun!
It will come in handy on the acreage, when I start messing around with shipping container garages.
- SA200 1.JPG (47.52 KiB) Viewed 9541 times
Score!WerkSpace wrote:I bought an old Lincoln SA-200 on my way home today. This welder has been converted for propane.
Miller Dynasty 280DX
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Victor Oxygen-acetylene torch
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Sweet!
I've burned a good 500# of rod on one or another of those well-made machines. I regret I never owned one.
I've been looking into how to adjust the 'auto idle down' time limit for the SA-200 welder to idle sooner.
Reference: http://www.lincolnelectric.com/Assets/U ... VM224A.pdf
The following diagram shows the electronic circuit board that controls the idle solenoid.
Note that there are two reed relays used as 'idle sensors'. The Auxiliary power idle sensor is on the board.
The DC generator idle sensor is mounted off the board. These are made with a magnetic coil and magnetic reed relay.
The idea is that when current is drawn via welding or via the auxiliary outlet, current passes thru a coil.
The coil creates a magnetic field and this field is used to activate a magnetic relay as a switch.
Resistors R1 and R2 are used to bias the transistor Q1 which turns on the power transistor Q2.
Q2 will have the current capacity to operate the idler solenoid which mechanically moves the throttle linkage on the engine.
The capacitor C1 is used as the delay mechanism. Lower its capacitance value and the engine will idle down sooner.
- SA200 Auto Idler Circuit.jpg (34.15 KiB) Viewed 9511 times
- SA-200 Faceplate.jpg (36.6 KiB) Viewed 5518 times
My welder has the propane conversion and uses a Continental engine (with magneto).
The generator is DC, so it provides a very smooth arc. No rectification or filtering required.
The welder has 5 amperage ranges that overlap and a fine amperage control.
The advantage of this setup is that the fine amperage control can be used to alter the characteristic of the weld.
The fine amperage control is used to adjust the percentage of one of the 5 amperage ranges.
It's also used to set the voltage, which is very important to the characteristic of the weld.
Example:
175 amps can be achieved on 2 of the 5 ranges. (240-160) and (190-120).
Use the fine amperage control to set your 175 amps (and voltage).
Remember, as the voltage goes down, the amperage goes up.
Voltage controls the height and width of the weld bead, while amperage controls penetration.
If you want a hard (arc force/dig) type of weld used on vertical or overhead
select 240-160 and set the fine amperage control setting for a lower voltage.
Increasing amperage while lowering voltage creates a narrower weld bead,
deeper penetration and a more fluid (hotter) weld puddle.
If you want a soft (buttery) type of weld used for normal horizontal position
select 190-120 and set the fine amperage control setting for a higher voltage.
Increasing voltage while lowering amperage creates a flat, wide bead with shallow penetration.
Long arcing also causes the weld puddle to freeze faster because it lowers the total amount of energy available.
Reference: http://www.millerwelds.com/resources/ar ... -training/
Bill Beauregard wrote:Several days ago I was welding vertical, and overhead lap joints on 3/8 plate. I was outside, it was snowing/raining. I was using some very old Certanium mild steel welding rod. I was on a 12' ladder. My helmet was fogged inside, drizzling outside. Conditions were less than optimal. The resulting welds were not as ugly as I would have expected! That got me on the track of wondering if there was more I could do to improve.
Travis Field has a video on U tube showing how to adjust a 1959 Lincoln SA 200 for vertical up welding. He makes the point that a low voltage/high amperage setting will work much better for "stacking metal" The low volt/high amp setting allows the welder to push the rod deeply into the base metal at the left, making a deep, small diameter puddle. Then move across to the right, repeating the process there. By the time one moves back to the left it has frozen, as the depth leaves the molten puddle surrounded by steel, it cools quickly. The high volume of rod deposit melting serves further to cool the surrounding.
I don't have an old Lincoln Pipeliner's welder. Of several stick welders I own, only the two 1970s vintage Twentieth Century clunkers have voltage choices. Weather is too cold to go try them. Is there a way to influence voltage on say a Bobcat 250, or a Dynasty 280. I've thought of coiling lead cable around a steel object, I think that limits both voltage and current. Arc length won't work as higher voltage will stop the arc and stick without a long enough arc.
Is this what makes these old Lincolns so revered?
Apparently notweldin mike 27 wrote:If you set a Lincoln welder the way Miller suggests, would the world end?
I have a machine that has the engine and frame of a miller big 40 with the generator from a lincoln sa-200. No rips in the fabric of space-time seem to have occurred.
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Lincoln 210 MP
Miller 625 X-Treme
Hobart Handler 150
Good to know. Just don't use 6013s and 7018s on the same job or we are all doomed. Doomed, I tells ya.
Miller and Lincoln play very well together.
Today, I bought a Miller X-treme 12VS for my SA-200.
My engine driven welder now has Stick, TIG and MIG capability. Very cool...
https://www.youtube.com/watch?v=Ar1TxSYEg38
https://www.youtube.com/watch?v=aueqgwqZg08
- Miller X-TREME 12VS.jpg (52.44 KiB) Viewed 5479 times
I've used the 12VS with a Lincoln Invertec 275 as the power source.
Seemed to be a peaceful marriage.
I like the fact that the drive rollers are interchangeable with my Millermatic 210 shop machines. It came with .045" flux core rollers and I typically use .035" solid core rollers on my shop machines. So, I borrowed the rollers from one of my Millermatic 210s to fit the suitcase machine. That Millermatic machine is setup with a spool gun anyway, so it won't miss those rollers as they are never used.
The only thing remaining to do was purchase some .035" contact tips for the Bernard 400 amp gun. $16 for ten tips on eBay including shipping and they are already on their way.
One thing that I noticed is that this suitcase weighs 35 lbs empty and about 80 lbs when you fit 12" spool of wire in it. I might figure out a way to put some wheels on this case. Afterall, who wants to lug 80 lbs around, plus all the extension cables.
Otto Nobedder wrote:I've used the 12VS with a Lincoln Invertec 275 as the power source. Seemed to be a peaceful marriage. Steve S
Fabulous to see the kids playing together. Now we need to get the parents more friendly. Baby steps eh?
ryan.k.mcdaniel
- ryan.k.mcdaniel
WerkSpace wrote:SA-200 Faceplate.jpgI recently bought a Lincoln SA-200 welder, so I got more interested in this topic.
Example:
So I have a question about finding the setting for amperage on this face plate. I weld daily with an SA200 on pipe.
For my example I'll use the selection that I was using just today capping a 6" schedule 40 with a 5/32 70+ (8010) rod in the 3rd gear (190-120) with the rheostat at about 65.
My mathematical reasoning says that gear has a range of 70 amps which I divide 9 time to give me the increment value of 7.77 amps per every 10 units on the fine current adjustment.
7.77×6.5=50.55
50.55+120=170.5 amps sitting on 190 and 65
To achieve 170 amps in the 240 gear with this reasoning would be described as
240-160= 80
80÷9= 8.88
8.88×1.5= 13.33
13.33+160=173
This would mean that to get the same amperage in 240 gear as in my normal operation I would have to have my rheostat set in between bottoming out (10) and 15.
I can with out a doubt promise that if I tried to fire up with a 5/32 on 240 and 15 I would have a very difficult time maintaining my arc and would not be putting a decent cap on with the rod due to it. I figure that I would be closer to around 30 on the rheostat.
Similarly when running the 3/16 70+ rod I am capping on 190 and 75/80 or 240 and about 50/55 or 178/182 & 204.4/226.6 respectively.
If the rheostat dial is supposed to be a percentage of the range selector and that the same amperage can be obtained, why is either my mathematics or my amperage selection so far off.
I am ignoring travel speed in the equation as well as the possibility of arc length variation due to the open current voltage being set at 93 at 100 on the rheostat in either gear.
Any clarification?
I don't weld pipe and am strictly part-time.ryan.k.mcdaniel wrote: So I have a question about finding the setting for amperage on this face plate. I weld daily with an SA200 on pipe.
7.77×6.5=50.55
240-160= 80
80÷9= 8.88
8.88×1.5= 13.33
13.33+160=173
Any clarification?
I divide by 10 because the math is easy.
Lowest (0) corresponds to lowest in coarse range (120).
Highest (10) corresponds to highest in coarse range (190).
Add or subtract 7 between (in this case).
Just because the amp ranges overlap doesn't mean a particular rod runs well in both theoretical math equivalent settings.
"Adjust recipe to taste."
