http://www.weldingtipsandtricks.com/sti ... ckets.html
Saw a lamp on instagram made by @superiorwelding using threaded pipe so I made one with socket weld fittings.
best,
Jody Collier
6UPBpeW9tFE
DeepSouthWelder
- DeepSouthWelder
Thanks for the reply ,I did not see the machine in the video until I watched it again just now. Excellent video as always and I believe that type of bulb you used on the lamp is called an Edison bulb.
Instagram : natecreel1050_
- castweldsolutions
In one of Jody's older videos, he tig brazes cast iron to stainless, and he does it in AC in order to use a high negative balance, and increase the cleaning action.
In this video, it appears as though he welded it in DC-? Can anyone confirm what polarity he used in this vid when he was using the silicon bronze? Is AC only advised when joining cast metals?, and DC- for all others?
Just curious. Once again, great vid and it too has got me wanting to go make a lamp lol.
Tyler
- admin
- Site Admin
I used DCEN (straight polarity) for this video. silicon bronze welds pretty clean on DCENcastweldsolutions wrote:In one of Jody's older videos, he tig brazes cast iron to stainless, and he does it in AC in order to use a high negative balance, and increase the cleaning action.
Aluminum bronze welds much cleaner on AC
best,
jody
- castweldsolutions
