Gavin Melville
    Fri Jul 03, 2015 6:31 am
    Christchurch, New Zealand
I've been using mixed arc for welding Aluminum for a while, and weld wise all is good. I run 200 ish amps DC, 60% of the time, AC at 60% of that current. The AC is 250Hz, square wave, 62.5% EN. I am welding thin to thick, say 1" to 1/8", and get deep penetration and narrow welds.
The problem is tungsten life. The ends of the tungstens are shredded, like when you get a split, except I get 20 splits. Tried all kinds, zirconium doped, lanthanated, even thorium doped. The best results are with rare earth (E3) in 1/8", one size up from what I usually use. They still shred, but last longer. Prep is a short cone, no ball as per Kemppi's recommendation. I end up regrinding every 10 minutes.
Is anyone else running mixed AC/DC on Aluminum?
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
I'm not running mixed DC/AC but am interested in your other settings
Your AC is 250Hz, Square, 62.5% EN - OK
What is the switching frequency of the DC to AC?
Are you running EN in the DC part of the cycle?
200 Amps on a 1/8" electrode should be OK.
What gas? Is it a Argon/Helium mix?
Gavin Melville
The DC / AC switching rate is 0.6Hz, and the DC is EN. Gas is pure Argon.
I may have found the problem, or at least part if it. I have lengthened the post gas time to 15 seconds. I suspect the electrode runs very hot in AC/DC mode, and needs gas flowing for longer to let it cool. The electrodes still look somewhat shredded, but not as bad, and now they are shiny. A work in progress.
TwentyFourSeven
    Sun Aug 24, 2014 4:41 pm
    Tarpon Springs FL
Only tungsten i have found that hasnt shreded tips has been the white band. I believe its zirconiated but you said you have tried that. Lanthonated and thoriated both split ends real bad on me. The white does a nice clean balled tip.
Lincoln Precision Tig 225
ex framie
    Sun Aug 09, 2015 1:09 am
    Brisbane QLD Land of oz
Noob question if I can interrupt, what is mixed dc/ac?
Pete
Gavin Melville
Running DC on aluminium part of the time, AC the rest, about 1/2 a second of each. The DC gives a tight arc with good heating, the AC does the cleaning. In my case welding 6061 aluminium where the thickness of the thick to thin metal is approx 10 to 1. It's noisy, looks good (auto dime maker), but blows the end off tungsten's. In all this is quite useful.
Been discussing it here;
http://www.mig-welding.co.uk/forum/thre ... -dc.58374/
ex framie
Thanks Gavin.
Pete
TwentyFourSeven
    Tarpon Springs FL
Does running on DC melt the metal faster?
Gavin Melville
The narrow focused arc melts the metal faster, the area is smaller. It's like welding Aluminum with the arc width and shape you get on Stainless. In my case I can use the penetration on the heavier metal, and run the AC on the thinner metal.
TwentyFourSeven
    Tarpon Springs FL
DC+ or DC-?
Gavin Melville
DC-.
DC+ would do bad things.
soutthpaw
    Thu Sep 18, 2014 12:14 pm
    Albuquerque NM
DC+ and a block of copper is great for balling tungsten with a transformer machine. Then switch to DC- to weld and you have a perfectly prepared tungsten to weld with
d.smith
    Wed Mar 18, 2015 11:14 am
    Maine
How are you grinding/cutting your tungsten to size? someone once told me that if you are using pliers or a tool to cut or snap it it may create small stress fractures in your tungsten and will split the ends while welding AC. The fix was to use a cut off wheel to cut to size then grind it. my tungsten splitting has been minimal since then.
hope that may help you.
