I have aquired a Smith Proportional Mixer but it is a Argon/CO2 model. It seems most of them that come up cheap are this model. I have done some research and found that it will work for Argon/Helium as well. The mixing proportion settings are entirely different. I have contacted the tech support for them that is now part of Miller. They were very helpful and told me there was a chart available that gave the mix settings for Helium using the numbers on the CO2 mixing dial. They e-mailed the chart to me. If any of you have a Argon/CO2 model or find one and would like a copy let me know and I can send you one.
Jim A
I don't have a manual so I don't know if it is like anything in the manual. It is identified as "Conversion Chart Mixer Model # 299-006-1B.
For example it says for a 25% Helium mix the mix setting should be 9.2. For a 50% mix the setting should be 23.2.
Send me your e-mail address if you want a copy.
I have the correct gauges.
jauguston@msn.com
jauguston@msn.com
soutthpaw
- soutthpaw
Y'all do know, you can send private messages within this forum, don't you?
Click the username of the person you're intending to send to; it will take you to their profile. Scroll down to the heading "contact so-and-so", and you can choose to send an e-mail to the person's address as listed with the forum, or send a private message directly on the forum to that username.
Private messages are just that, to us moderators. We cannot see them. I suppose the founding admins might be able to see them if there were a reason to look.
Otto,
I am aware of the PM function on the forum. Unfortunatly I am not computer literate enough to figure how to get a PDF file our of the e-mail from the Miller/Smith tech and then transfer it to a outgoing PM to a Forum. Way above my pay grade for a 76 year old guy. He sent me a traditional e-mail address that I have sent the file to twice. My computer shows the e-mails have gone through with no e-mail failed notice coming backs. I have run out of ideas.
If you have a e-mail address you want to send me I will try to send it to you or if you want to send me a mailing address I will be happy to print a few copies of it and mail them to you.
jauguston@msn.com
Update- I just sent the file the third time to the email address he gave me but this time I also sent it to myself. I got it right away.
jauguston@msn.com
If all else fails, send me a copy at sgfav8r@hotmail.com
I'll try to forward it, and failing that I'll convert it to a JPEG and send it as a picture.
Got it, Jim.
I've converted it to JPEG. I'll try to post it here...
- Mixer conversion chart..jpg (107.5 KiB) Viewed 2678 times
