Hello everyone!
I am new to the blog, but I have been following Jody on Youtube for some time. Anyways, I have been welding cross-country pipe for 8 years now, and I want to get into power plant and refinery work and need to pass some certs. Everything I have done before has been XX10 (6010, 8010) electrode all welded downhill. What I am needing to tackle now is a 6010 root with a 7018 fill and cap. To my understanding, isn't the 7018 fill and cap done uphill? I am asking this because I am currently taking a night welding course and the instructor is telling me that his test is welded downhill on one side of the pipe and then uphill on the other. Anyone ever heard of this before?
That sounds interesting. I've never heard of it but he may have had a weld procedure written up to cover both. My certs on pipe are technically all up progression.
Procedures that are written in accordance with ASME Sec IX can have uphill and/or downhill progression. There is some allowance for multiple variables to be used in a single coupon so what is being done may be valid.
Gerald Austin
If I didn't say it in the post- Have a great day !
Greeneville Tn
Greeneville Tn
Ski-Weld
- Ski-Weld
I just find it confusing since the information I have from Lincoln on 7018 says that it is good for all positions except vertical down. I have class tonight, so I'll be able to go over it more with my instructor to clear things up.
Thanks for the replies
TigMonster
- TigMonster
7018 is not a down rodColdman wrote:Does anyone know of a 7018 rod that is endorsed by the manufacturer for the vertical down position?
I've looked but had no success yet.
Sent from my SM-G920P using Tapatalk
Supposedly so but there has been alot of talk about it including use in qualified procedures and in formal training. Some state there are specific 7018 rods for this purpose.
Personally I don't think a wps is valid if it nominates a rod for a position not validated by the manufacturer. Also a I don't think a good trainer would do so either.
This is their chance to turn here say into fact.
That's not the point. I want the people who claim to have used down hand 7018 rods to tell us the make and part number of their rods so we can verify with the manufacturer that they actually exist.
Whatever... If you were to check Lincoln's website and check all rod descriptions the only rod the recommended was a 7016. I can regoogle and post the URL if you would like. Bottom line if the manufacturer doesn't recommend it, I wouldn't do it as you are now solely responsible and can go to jail for that weld failure. Enjoy your day
I have checked many websites including Lincoln and found the same as you which I already knew.
Your comments are correct and I agree with them.
There are plenty of people all over the web for a long time who claimed to have used 7018 down hand rods. None have given a brand or part number for these mysterious rods.
I don't claim to know everything (in fact I don't claim to know anything at all besides beer and bbq) so I merely ask out of interest if one of these people to please identify these purpose built down hand 7018 rods.
Just giving an opportunity before the bs call.
7048Coldman wrote:Does anyone know of a 7018 rod that is endorsed by the manufacturer for the vertical down position?
Gerald Austin
Greeneville Tn
Greeneville Tn
E7048 got it thanks,
Interesting. Finally we see a low hy vertical down hand rod. Not many manufacturers. I see Lincoln also have an E10045 which they also call a low hy down hand rod.
So to the original OP, your teacher knows what he is doing by making you go up and down on fill/cap. Are you using E7048 rods?
Anyone used these rods and care to comment on how they go?
Reading up on it I see you need to hold a tight arc and use straight stringers only, no weaving.
Ski-Weld
- Ski-Weld
I am using 7018, and come to find out that it is only for uphill. I'm not sure if my instructor was confused on what I was asking him last week or what, but I've got it all figured out. I think what he was talking about was the 6010 cross country pipe option for downhill and then the 7018 fill and cap uphill. They are two different tests.Coldman wrote: So to the original OP, your teacher knows what he is doing by making you go up and down on fill/cap. Are you using E7048 rods?
I did look into the 7048 LH rod for downhill, and that would be yet another certification. We have to remember that a cert test is only good for each position, process and material.
plain ol Bill
- plain ol Bill
Esab - atom arc.
Tired old welder
CNC plasma cutter
Colorful shop w/
CNC plasma cutter
Colorful shop w/
Thanks Bill. Checked with the manufacturer regarding Atom Arc 7018:
"Hi Vic,
Although these electrodes are referred to as all positional, they are not suitable for use in the vertical down position.
Regards
Technical Services
CIGWELD PTY LTD - An ESAB Brand
71 Gower Street, Preston 3072, Victoria, Australia
T 1300 654 674 D +61 3 9474 7412 F +61 3 9474 7361"
"Hi Vic,
Regards
Technical Services
After all the searching I've done I decided to ask a pipeliner buddy of mine if he knew of such a rod. He said "sure they're called 27P rods. Cantankerous rods to get used to due to the thin flux coating but work good once you get used to them. Particularly at starts, if you lift the rod slightly striking an arc the weld looks like moonbase 1. Gotta keep a very tight arc. Run on plates help alot for structural work."
So here it is: http://www.esab.ae/ae/en/products/index ... ode=410633
E8018 vertical downhill rods.
Very tempting for a video ain't it. You know its gonna eat away at you until you do.
Midwest_813
- Midwest_813
Hello everyone,
My name is Aaron and my message is for help concerning a pipe cert i'm in the middle of trying to take. It is either going to be done on 3" or 6" steel pipe done in the 5g position. I'm in school currently and have about a week left. I have already took two ther certs one mig 3g plate and tig 2f plate and passed both. My question is this. My instructors cant seem to find the correct code for this process to show me the exact measurements min. and max. of the length overall once the pipe is welded. I had everything beveled and ready at 30 % and they tell me that its not 8" overall that it might be 9" or even 12". So I have no time left and I'm freaking out because of time and the fact I paid extra for this cert. Please help. my email is midwest_813@yahoo.com or you can even call me 419-632-3046. Thanks a bunch . Need help asap.
ryanjames170
- ryanjames170
anyone here ever welded 7018 down hill? i have.. not fond of it
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
RM Fab & Products
AlphaWelder
- AlphaWelder
If you can ask to see their welding procedure it should detail which rod they use and uphill vs downhill. If you are doing a welder qualification for a contractor they should have a qualified WPS you are certifying against.
