Whatever... If you were to check Lincoln's website and check all rod descriptions the only rod the recommended was a 7016. I can regoogle and post the URL if you would like. Bottom line if the manufacturer doesn't recommend it, I wouldn't do it as you are now solely responsible and can go to jail for that weld failure. Enjoy your day
I have checked many websites including Lincoln and found the same as you which I already knew.
Your comments are correct and I agree with them.
There are plenty of people all over the web for a long time who claimed to have used 7018 down hand rods. None have given a brand or part number for these mysterious rods.
I don't claim to know everything (in fact I don't claim to know anything at all besides beer and bbq) so I merely ask out of interest if one of these people to please identify these purpose built down hand 7018 rods.
Just giving an opportunity before the bs call.
7048Coldman wrote:Does anyone know of a 7018 rod that is endorsed by the manufacturer for the vertical down position?
I've looked but had no success yet.
Gerald Austin
If I didn't say it in the post- Have a great day !
Greeneville Tn
Greeneville Tn
E7048 got it thanks,
Interesting. Finally we see a low hy vertical down hand rod. Not many manufacturers. I see Lincoln also have an E10045 which they also call a low hy down hand rod.
So to the original OP, your teacher knows what he is doing by making you go up and down on fill/cap. Are you using E7048 rods?
Anyone used these rods and care to comment on how they go?
Reading up on it I see you need to hold a tight arc and use straight stringers only, no weaving.
Ski-Weld
- Ski-Weld
I am using 7018, and come to find out that it is only for uphill. I'm not sure if my instructor was confused on what I was asking him last week or what, but I've got it all figured out. I think what he was talking about was the 6010 cross country pipe option for downhill and then the 7018 fill and cap uphill. They are two different tests.Coldman wrote: So to the original OP, your teacher knows what he is doing by making you go up and down on fill/cap. Are you using E7048 rods?
I did look into the 7048 LH rod for downhill, and that would be yet another certification. We have to remember that a cert test is only good for each position, process and material.
plain ol Bill
- plain ol Bill
Esab - atom arc.
Tired old welder
CNC plasma cutter
Colorful shop w/
CNC plasma cutter
Colorful shop w/
Thanks Bill. Checked with the manufacturer regarding Atom Arc 7018:
"Hi Vic,
Although these electrodes are referred to as all positional, they are not suitable for use in the vertical down position.
Regards
Technical Services
CIGWELD PTY LTD - An ESAB Brand
71 Gower Street, Preston 3072, Victoria, Australia
T 1300 654 674 D +61 3 9474 7412 F +61 3 9474 7361"
"Hi Vic,
Regards
Technical Services
After all the searching I've done I decided to ask a pipeliner buddy of mine if he knew of such a rod. He said "sure they're called 27P rods. Cantankerous rods to get used to due to the thin flux coating but work good once you get used to them. Particularly at starts, if you lift the rod slightly striking an arc the weld looks like moonbase 1. Gotta keep a very tight arc. Run on plates help alot for structural work."
So here it is: http://www.esab.ae/ae/en/products/index ... ode=410633
E8018 vertical downhill rods.
Very tempting for a video ain't it. You know its gonna eat away at you until you do.
Midwest_813
- Midwest_813
Hello everyone,
My name is Aaron and my message is for help concerning a pipe cert i'm in the middle of trying to take. It is either going to be done on 3" or 6" steel pipe done in the 5g position. I'm in school currently and have about a week left. I have already took two ther certs one mig 3g plate and tig 2f plate and passed both. My question is this. My instructors cant seem to find the correct code for this process to show me the exact measurements min. and max. of the length overall once the pipe is welded. I had everything beveled and ready at 30 % and they tell me that its not 8" overall that it might be 9" or even 12". So I have no time left and I'm freaking out because of time and the fact I paid extra for this cert. Please help. my email is midwest_813@yahoo.com or you can even call me 419-632-3046. Thanks a bunch . Need help asap.
ryanjames170
- ryanjames170
anyone here ever welded 7018 down hill? i have.. not fond of it
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
RM Fab & Products
AlphaWelder
- AlphaWelder
If you can ask to see their welding procedure it should detail which rod they use and uphill vs downhill. If you are doing a welder qualification for a contractor they should have a qualified WPS you are certifying against.
I don't think "code" is the word you're looking for. They (better) know what code. It will be AWS D1.1 structural, ASME IX boiler and pressure pipe, API oil and pipeline, etc. You're going to have to narrow the field if you want anything resembling a pre-approved procedure and accompanying specifications.Midwest_813 wrote:Hello everyone,
What sanctioning body are you seeking the certification for? AWS?
americaniron
- americaniron
Hi guys, first off, thanks for letting me in, i am from Slovakia and i am proceeding thru basic TIG test, where i learn lap joints, flat plate joints, horizontal and uphill welds, i started with basic carbon steel, then get some skills and then i tried stainless steel, it went all done, it was fun and i made it in 2 weeks, then i moved to pipe welding and first off i started weld on table with my pipe fixtured, made weld, then turned it, welded again, etc. Then they showed me some king of 6g position and i used metal prep like Jody learned me from videos, i made tacs, but then i started to weld from 6 o clock position uphill, they told me i have to make it free handed with no fingers helping me to stable arc and so on, so i was mangled in weird position my hands were shaking and i couldnt make any good weld, i kept sharpening my tungsten after almost every weld, it was all bad. I tried lots of techniques and i got little better but still its not acceptable for me.
Here are my questions and things i found problematic for me
-Will i be better welder by doing free handed welds without fixing my hand on metal for stable arc? I just dont think so, because if i prep my hand and rest my finger on pipe, i make decent weld in almost every position, but free handed, its bad...
-i was using Fronius MagicWave 2200 Job in welding school, it is 4000$ machine with all kinds of settings, including pulse, ac/dc, 220 amps capable, HF start, etc, it has also water cooled torch, but the torch had buttons for starting arc but it is really hard for me to reach that button in weird postions when doing 6g test weld, thats why i ask if its better to go with fancy expensive torch with 360 angle head settings, without buttons but buying pedal instead, or if i should stay with that torch and learn with that ?
-next thing was my rod, when i was trying to do dip technique adding rod to puddle it sticks to puddle or somewhere else everytime so i dont know what am i doing wrong, i tried different angles, tighter arc, longer arcs, my rod just got glued almost everytime i sticked it to puddle and tried to take it out, hard to explain without showing... thats why i stayed with lay wire technique almost in every weld i made...
-next thing is tig finger i bought here in Slovakia, i dont know what i made wrong with it but it seems like it is very brittle material (Silica fiber), but i prepped my metal plate, i grinded it, then polished with sand paper grinding wheel, deburred edges and it was safe for my bare finger to slide on that edge, then i slided it with tig finger and it tore even more, after 4 passes it ended up in trash, is it really that brittle when you buy that from Jody ? I couldnt get that Jody´s because he sent only in USA so i had to buy this shit....
- 20891388_10203109007283385_196505243_n.jpg (83.39 KiB) Viewed 3112 times
- 20930290_10203109008123406_24262401_o.jpg (75.76 KiB) Viewed 3112 times
- 20930393_10203109035644094_364971508_o.jpg (73.3 KiB) Viewed 3112 times
