ajlskater1
- ajlskater1
Had to weld up 200 of these on Friday. Was a good challenge. The material was .070 5052 and the hole was only .090 away from the edge of the hole and customer didn't want the hole to be distorted.
- 20160611_004753.jpg (24.53 KiB) Viewed 2906 times
- 20160611_004738.jpg (36.63 KiB) Viewed 2906 times
- 20160610_231432.jpg (30.53 KiB) Viewed 2906 times
ajlskater1
- ajlskater1
I am using a dynasty 350. It is a part of this larger assembly we do for this company. Not sure it's exact use.LtBadd wrote:Nice work, what machine are you using?
- 20150408_162742.jpg (32.36 KiB) Viewed 2885 times
- 20151222_164752.jpg (23.67 KiB) Viewed 2885 times
ajlskater1
- ajlskater1
Thank you! Not sure it's on the same level as your work! Love seeing your bike frames!zank wrote:Beautiful!
ajlskater1
- ajlskater1
Was a nerve racking couple hours of welding lol. Had to focus really hardmotox wrote:and two hundred of them, holy crap.
awesome
ajlskater1
- ajlskater1
- DLewis0289
Outstanding quality!
Looks awesome! I love 5052...
"No pulse. I used 200 en 115 ep balance of 60 and frequently of 100"
did you start at 105 amps and just peddle the pool?
I believe that means that he has a machine which will allow you to set differeng amperages for the positive and negative sides of the ac waveform. Jody showed one of those machines in a video recently.
Raymond
Everlast PowerTIG 255EXT
ajlskater1
- ajlskater1
This is correct. The dynasty 350 allows you to independently change the en and ep sides of the actual wave form and change the balance all independently. Those were the setting for the little part. The other part I set the machine at like 350 en 250 ep 70 percent balance and 250 hz, that's normally how I do mostly aluminumunless it's really thin or dirty. I don't max out the pedal, I like to feather itRamboBaby wrote:I believe that means that he has a machine which will allow you to set differeng amperages for the positive and negative sides of the ac waveform. Jody showed one of those machines in a video recently.
